Expression pedal
Started by buckle, October 18, 2013, 12:19:26 AM
buckle
I'm still pretty new to the world of pedal building. I am trying to build an expression pedal from an a crybaby with the 100k hot pot, but want to put a switch to alternate between the treadle and a 100k pot I am going to mount to the side of the pedal. I think I can do this part, but it would be cool to add an LED as an indication to which pot is active. Would this require the use of a 3pdt switch?
"Wanting to be someone else is a waste of the person you are." - Kurt Cobain
kothoma
Quote from: buckle on October 18, 2013, 12:19:26 AM
Yes, a 3PDT would work:
1 pole for switching between lugs 3.
1 pole for switching between lugs 2.
1 pole for the LED.
If you could live with 50k resistance and a bit of a taper change, you could wire lugs 3 in parallel and only switch lugs 2. Then a 2PDT would suffice.
