new DMM
Started by gtangas, October 27, 2013, 12:13:29 PM
gtangas
Hi guys
Need some advice on a new dmm...
Initially I thought on buying the vichi vc99... Cheap and lot of features but after seeing some reviews I'm having some doubts about it
I saw the uni-t ut61 series and its another machine... The top one is the E model but no temp or HFE
My older and very cheap unit as the HFE feature so I can use it for that or maybe buy a components testes in eBay... They are cheap
And with that many different options maybe you guys can give some guidance... I don't want to spend more than 65usd...
Thanks
Sérgio
Thomas_H
I have the uni-t UT 603 (which has hfe, cap, resistor and inductors) but NO voltage and a UT 803 which I got used.
They are really sufficient in combination.
DIY-PCBs and projects:
gtangas
The unit units have very nice reviews, especially the ut61e...
The 61b or the C have temp but I read on eev blog that the continuity test is slow... The autorange same thing but with that I have no problem...
Thomas_H
Quote from: gtangas on October 27, 2013, 12:39:51 PM
Yes, continuity test is somewhat slow, but its not really the test, its more that the beep is delayed for a reason. autorange works fine for me.
gtangas
Ok.. But a bench one is expensive...
Any experience with the Victor VC97 3.. The one with backlight?
I saw some units on amazon and ebay... But can't find any review on those meters
It's kind a like the Vichy but the overall construction seems a bit more nicer
