TL072P and TL072CN for the sea urchin
Started by Gledison, September 26, 2013, 07:57:28 PM
Gledison
hey guys, just need to confirm something.
ive ordered a TL072 from Tayda and received a TL072 CN. On the sea urchin schematics a TL072P is described.
I've checked on google and some pages says that there are little differences, others says that is just a manufacture type of package or op. temperature...
any hints? just want to be sure im using the right thing :P
For our purposes, they are exactly the same.
DutchMF
go ahead and use the ones you have. It's just a matter of packaging and/or max/min operating temperature. Usually these kind of things don't really matter when building a pedal. One exception I can think of are chargepumps, with those, the extra letters matter a lot!!!
Paul
Gledison
das234
I concur.  I used the Tayda one in my Sea Urchin and it works fine.
papasaurus84
thousand dollars pedal and DIY is a GAS. the diffrence is the voltage: plus and minus. :D
Gledison
Great! Byyy yhe way! Iv got only 50k log pots for the sea urchin! I think would be ok to switch instead of the linear pors right?😛
papasaurus84
all of mine is B50K. IMHO, so far so good. an A and C in my country cost waaaay more expensive. so i use the cheap one. :D
