Testing rig problems
Started by playpunk, September 07, 2013, 01:20:09 PM
playpunk
Hello oh patient madbeaners.
A couple of days ago, I put together a basic testing rig as described by jkochura. I used it to test a ego driver, and the pedal didn't work. Today I used it to test a treble booster, and it didn't work. So I tried to test my testing rig, by hooking up the "in" and "out" clips, and IT didn't work, or pass the guitar signal at all. I have an audio probe attached to the output jack, and it works fine and passes signal perfectly.
What the heck?
"my legend grows" - playpunk
croquet hoop
Do you have a schematic of the test rig in question ?
First things first, check visually that the wires effectively go where they should go (especially the jacks).
playpunk
well i reflowed the solder on the output jack and now everything works. now for the circuit troubleshooting
