Applying Solder Mask
Started by teknoman2, November 05, 2012, 02:39:14 PM
teknoman2
I would like to use solder mask for my pcbs (to make them easy to solder them), but I don't know the process to apply solder mask.
I found this product on ebay :
http://www.ebay.com/itm/1pc-PCB-UV-Curable-Solder-Mask-Repairing-Paint-Green-/200617690716?pt=LH_DefaultDomain_0&hash=item2eb5bf065c
How can I apply solder mask in an etched pcb?
Any thoughts?
Haven't used such a thing so I can't be of help. But, an alternative that is quite cheap is to use a lacquer spray can. You can coat the traces and pads in one shot. It will preserve the copper and you can solder right through it.
teknoman2
How can I use a lacquer spray can?
Can you explain the process?
I am not familiar at all how to make a green solder mask.
teknoman2
Does anyone have any instructions how to apply solder mask
and which material should I use?
Gledison
Quote from: teknoman2 on November 05, 2012, 07:35:45 PM
maybe too late...but I just posted something about it..
http://www.madbeanpedals.com/forum/index.php?topic=10958.msg98545#msg98545
