Voxy Brown
Started by fendman, July 09, 2013, 06:21:06 PM
fendman
Built this up and boxed it a few weeks ago, but forgot to put it here, until Ian was asking for some Transistor Volts readings.
I wired the stomp switches different. Thats not saying Jubal's is wrong :)
Not a stand out and hit you pedal, but it sounds ok and with the boost its much better.
Quote from: fendman on July 09, 2013, 06:21:06 PM
It's the purple box. The color impedes the imperceptible harmoics.
Slick job! Viva le side pots!
QuoteNot a stand out and hit you pedal, but it sounds ok and with the boost its much better.
I can agree with this also.. kind of the reason I have not boxed mine up. I did find that it sounded 100X's better in my Bassman 135 than my Twin Reverb Reissue. In the twin is was very top heavy and piercing.
I might take your lead and mount mine the same. Looks great.
fendman
Hey guys, appreciate the comments :)
atreidesheir
[/quote]
Quote from: selfdestroyer on July 09, 2013, 11:20:38 PM
My English Channel pedal sounds much better plugged into a PA than into a guitar amp.
ch1naski
What's that you've done with the pots and vero ? Makeshift board mounts?
Sent from my Nexus 7 using Tapatalk 2
one louder.
fendman
Quote from: ch1naski on July 11, 2013, 05:57:28 PM
Hi,
Yes,  I spent a little time getting this right and it works for me...it is also very neat.
The board mounted pots I can only get from USA and Germany so its quicker to do it this way,and
probably in the long run cheaper.
Thanks
Mike
