RAH switching wiring diagram..?
Started by idgit, June 18, 2013, 02:22:40 AM
idgit
not sure if this is the place for this.  I've built a RAH clone and it doesn't work.  I've checked the board over  and over and it seems like it's clean.  I followed the standard Madbean jack/switching diagram for the routing.  I think I may have done this incorrectly or possibly there is a different way to wire the jacks/foot switch.
help appreciated
thx
idgit
i did not put it in the box.  i wired it up per the diagram and first did it wrong, the signal bypassed trough on or off, then I revisited the diagram and nothing when engaged.  Bypass is good though.
I remember seeing some folks wiring up the switched and jacks differently, not sure if the "standard" applies here
I'm going to go through it one last time and then rebuild, or perhaps I'll learn to trace it though with the multimeter to find the glitch
Thx
