Stratobooster mod help??
Started by Jallenfuzz, June 04, 2013, 05:11:23 PM
Jallenfuzz
I was interested in taking an alembic stratobooster circuit board from GGG and adding a tone filter cap to cut out the low end via a switch. To allow me to toggle between a full stratobooster boost and a treble boost.  I was looking for some advice.. I was thinking to put a .0022 or .0068 cap between the input and the transistor.  I would be switching between no cap and cap.  Does this sound like it would work??
It could work.
Do you have a breadboard? My highest recommendation on doing mods is to breadboard a circuit. That way, you can build the circuit, test it, and never have to use solder to make it permanent.
