Nautilus Question
Started by Droogie, May 23, 2013, 06:26:24 PM
Droogie
Just boxed up a Nautilus and am really enjoying it! Not having owned anything like this before, I'm not sure if some of the sounds I get at certain settings are just part of the circuit (gating at extreme Gain and Sweep) or if there's an issue. There's so many usable sounds and everything seems to have the right effect when tweaked, I'm tempted to say it's cool, but still curious to know.  Thanks!
Hangingmonkey
I dont ever recall getting gating from my nautilus. Theres loads of usable sounds but it needs to be dialled into to get the sound youre after and different to say a dirt pedal where every setting is usable
wstimson
Yeah, there are definitely some unusable settings on the Nautilus.  Sounds like yours is working fine.  :-)
Droogie
Thanks, I'll keep on digging it!
octa805
Make sure the internal trim pot is set right
Mine was done per the instructions and it was backwards and way loud and gated
Droogie
It is pretty loud with gain up—I'll check the trim.
Quote from: Droogie on May 24, 2013, 11:53:39 AM
This is normal. It's a very loud pedal, and not really the sort of thing meant to run at unity volume. My personal opinion is that it was never even meant to be turned on and off several times in the same song ...
The trim is the gain of the final op-amp stage, and really it's only there to provide a little boost if the pedal is too quiet in your favorite settings.
Droogie
There's definitely a learning curve for this one, which is kinda cool. I notice that due to the envelope settings, it can seem as if it's quiet—until you pick harder and it suddenly gets loud enough to disrupt gravity!
Trying out new sounds is one of the great things about DIY, though. I probably never would have bought an actual Mutron since the sounds it creates aren't usually associated with the styles of music I play. But being addicted to building leads to making things like this and then realizing the possibilities.
octa805
I didn't immediately fall in love with it because I didn't get it. Too many things to tweak.
Then I found a few settings that are just awesome. Putting a bit of a short delay behind it and doing some hard reggae/funk style chucks just makes it great and the delay kind of smooths it out
