Voxy Brown wiring question
Started by DutchMF, May 19, 2013, 04:11:51 PM
DutchMF
I'm getting ready to wire up my Voxy Brown, and had a question about the bypass/boost wiring: does the boost sound any good on it's own? I mean, should I wire it so it can be used on it's own, or only used when the entire pedal is on?
Paul
I mentioned quite a few revisions I'd like to make to it in another thread, partly because of this issue.
It's designed to be wired as two separate effect, with the boost pushing the OD.
Of course you can wire it however you like, but after using it for a while, if I were to build another, I'd put the boost on a DPDT toggle switch instead of a stomp.
I never use the boost on its own and I don't find any need at all to switch it on the fly. With it off, great, great OD. With it on - High gain Queen - that one particular sound.
DutchMF
Thanks for the reply Jubal. I've got the box already drilled for a stomp, so I'll try that first and wire it up so the boost can only be on when the rest of the pedal is on.
Paul
