diy reverb recommendations
Started by nieradka, April 23, 2013, 08:34:01 PM
nieradka
Hey, Im looking for a self etchable reverb project to work from. Im looking for an over the top reverb for shoegaze/wall of sound type of thing. Does anyone know off hand if any of the DIY projects will do that sort of thing, and/or which of the projects should be avoided in general?
Searching around I found, the rub-a-dub, stage center, ggg d-verb, tonepad fv-1, and the equinox/soltice, are there others?
Grind Customs Tenebrion is more that way inclined and most excellent.
micromegas
Mr. Thomas_H is selling a pcb for a reverb with a tone pot. Haven't tried it yet, but it seems to be simple and efficient. :)
Software Developer @ bela.io
greysun
I built a couple rub-a-dubs - if you get the long delay reverb module and turn it up all the way, it does produce some decent reverb.
I highly recommend them.
He (1776effects.com) also sells them prefab for like $8 or $9... Just fyi, but i get wanting to etch your own - it's what I did, but I redesigned the layout and used a SIP IC (can't remember the number right this second, though) instead of a tl072 to save a little space so I could shove it into a smaller enclosure and still have a battery.
Good luck!
nieradka
Ok thanks, ill try those, yeah, I prefer to etch my own, it feels more proper, and I have access to a good etching setup. In general, is there ethical questions, if i take the grind customs schematic and make my own layout?
Quote from: nieradka on April 24, 2013, 07:56:33 PM
You can certainly make your own layout from any schematic. No foul in that, at least not in the DIY world.
