Help me find a creative use for this enclosure.
Started by pk1802, June 08, 2013, 09:53:36 PM
pk1802
This box is from a failed project that was attempted, but never accomplished, many moons ago.
I think it was supposed to be a true bypass looper and wet/dry loop together, or something weird like that.
Now I have a box with two 3PDTs two sets of jacks and one knob(the light up knobbie can go if I need more space). Every time I walk into my work space, it's sitting right there, staring me down, mocking me for making it the mutant that it is.
I was thinking two different boosters. I already have a lpb1 and a couple germ boosters, both in one box would be nice, but I am sure there are some better ideas. I could also flip the box and do one switch where the pot is and use the holes for the switches for pots.
What say you madbeaners? Any idea of what I can jam into this box? I am ok with using the battery area for circuit board area.
Cortexturizer
Don't give up on those bypass loopers man, I have one and it's my most useful pedal!
Here, follow this lead
http://experimentalistsanonymous.com/diy/Schematics/Buffers%20Switchers%20Mixers%20and%20Routers/Feedback%20loop.gif
or, this if you want LEDs
http://aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=2587&g2_serialNumber=2
You can do it!
And you will experience some truly unique sounds via the feedback option.
DutchMF
Right after you said '2 boosters' I was thinking Firebomb! I have one and it is very, very cool! Makes your amp sound like it's gonna blow up, without losing your original amp tone. Might be a tight squeeze to get the 2 extra pots and the board in there.....
Paul
pk1802
Quote from: Cortexturizer on June 08, 2013, 10:52:22 PM
You can do it!
Thinking back, I think that the loop was supposed to be a wet/dry blend on one switch and, a series parallel loop on the other. I believe it is possible, but I need a 4PDT to complete it. Also, I've found another work around for what I was trying to accomplish then. Thanks for the links though, I bookmarked them both!
Quote from: DutchMF on June 09, 2013, 06:24:22 AM
Paul
It would be cool to each booster in different locations of my chain, before and after ODs, etc. Is the firebomb based on the SHO, or a different boost?
DutchMF
The Firebomb is basically 2 SHO's bootstrapped back to back, with the last one having an added MV. Not really suitable for what you would want, but that would also mean adding 2 more jacks tot the whole deal... Could you it that all in that box?
Paul
