LED for a battery power mangler
Started by Bman40, March 10, 2013, 10:55:18 PM
Bman40
Hey all
Can I get some advice on how to add an led to a battery powered positive ground mangler? I'm using some ge transistors from small bear ..I,don't want a road rage board in this.
I found the wiring diagram on the mangler project page, but its left me a bit confused :  the diagram shows the black lead from the battery going to the flat side of the led and the round side then going to the footswitch (top left pole).   Where does the 9v power wire to the pcb connect?
Thanks
Barry
pedalman
the switch controls the +v. led on/pedal on, led off/bypass
make sure you put a resistor on the led
Bman40
Thanks I did that and now there,is no sound at all.  Bypass works, but no fuzz.
pedalman
make sure te led is wired properly (flat side/round side)
Bman40
I'll check again tonight.... thanks
pretty sure I had it right, but .....
B
Bman40
The led lights up btw... But no sound
Quote from: pedalman on March 11, 2013, 04:21:08 AM
Even on a +ground pedal? Do you just wire it backwards? Or is that what you just said? Also if the sound goes away,its a grounding issue,unwire it the LED and see if it comes back. If so then we need  plan b.
Bman40
it DID work fine before i put in the LED.
ill pull it out again and see. I was having a problem with a huge buzz - but i realized it was nt grounded (sittign on the carpet outside the enclosure) when I connected the grunds with a temporaty wire - perfect.
I assume that once its in the enclosure it will be fine.
pedalman
#8
its got to be a ground issue, pluck it from the box if you have to. if its out of the box, make sure both jacks are grounded. also rewalk the ground path. i hae wasted hours all because i forgot a small part in the ground path
