sea urchin pop issue solved. Now a clock noise on the background!
Started by gtangas, January 22, 2013, 03:00:11 PM
gtangas
Hi guys
Need some help to kill the "pop" of my delay pedal!
i´m using a super bright blue led. does it matter? and 4.7k resistor
thx
Sergio
Stick a 1M resistor from the output to ground.  Easiest way is to just put it across the tip of the output jack to the sleeve.
Josh
gtangas
Quote from: gtr2 on January 22, 2013, 03:14:21 PM
Josh
fx output?
Haberdasher
you can use a 100k there and it works fine in my experience, in fact I think madbean is the one who originally suggested the lower value.  IIRC I used a 120k and I have no pop.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
ditto 100k works for me in all iterations of the "deep blue delay" architecture that I have made
I solder it to the footswitch FWIW...
gtangas
#6
ok problem solved
The 100k works fine!  ;D
now i hear some clock noise! not to loud but when mute the strings i can hear a noise like a clock. i´m supossing that the pt2399...
Another guess and doubt... i didnt use the footswitch wiring indicated by MB
I use a this key:
This key can affect the signal?
Its the pt2399.  Some are louder than others when it happens.
gtangas
Quote from: gtr2 on January 22, 2013, 11:37:55 PM
Ok
Look can you explain the need of connect the fx in on to the empty center pole of my wiring key?
The bypass you indicated is fine, with one exception. What doesn't happen with that version is that when you are in bypass, the circuit still holds potential DC voltage. What we often do is 'ground' the input of the circuit just in bypass. So, to accomplish this, I would connect the upper left lug to the lower middle lug as well as everything else you've done. In fact, that's how I do my bypass every time I build.
The Madbean 3PDT scheme accomplishes exactly the same thing, but does it in a different way. If you want to understand it, or the bypass scheme you posted above, I highly recommend you read up on how switches work. I know Beavis Audio has a great Switch article.
gtangas
thx for the explanation.
I found the Beavis article on switches, nice one btw, and i will add that extra connection.
Obrigado
Sérgio
