Green Bean-->CJOD mod
Started by jtn191, February 09, 2012, 10:46:15 PM
jtn191
Ever wanted to make a Clay Jones Overdrive, aka CJOD? Now you can! This is the BOM you'd need to use with a Green Bean PCB to do so
Differences are in yellow
R1: OMIT
R2: 1k
R3: 510k
R4: 10k
R5: 10k
R6: 1k
R7: 10k
R8: 1k
R9: OMIT?  ???
R10: 220R
R11: 1k
R12: 1k
R13: 510k
R14: 10k
R15: 100R
R16: 10k
R17: JUMPER
R18: 10k
R19: 10k
C1: 20n
C2: 1uF
C3: 51pF
C4: 220nF
C5: Socket this position...try something lower than 150nF? If your fat switch sounds too dark, try something at a lower value
C6: 220nF
C7: 220nF
C8: 1uF
C9: 100nF
C10: 10uF
C11: 47uF
C12: 100uF
D1-D5: 3mm red LED (or your choice for mod)
D6 1N4001
Q1: BC546B *check pinout
Q2: BC546B *check pinout
IC1: OPA2134A
*same switches as in stock BOM
Drive: 1Meg Log
Tone: 25k reverse taper
Vol: 100k B
you can find the schem at the bottom of this post http://solgrind.wordpress.com/2008/03/07/clay-jones-overdrive/
Ang3lus
schem says 100k reverse (vol), are you sure it's 10k ?
hammerheadmusicman
Where can i get one of these Op Amps? Also, is that the Burr Brown? I read somewhere that's what's in the CJOD, i think?
George
oldhousescott
Yes, that's the Burr-Brown. Most of the usual suspects carry it: Mouser, Small Bear, Mammoth, Tayda, etc.
hammerheadmusicman
Sweet, I'm on this! Has anyone else built it? Does it live up to the "Dramatic Overhype"? ;)
George
