LED/LDR questions
Started by angrykoko, December 14, 2012, 05:46:48 PM
angrykoko
Working on a shoot the moon, I found I had an LDR in the right range but I'm wondering about the LED to use.
I have yellow/red/green diffused
and only blue clear.
Q:  which LED would I be best off using?
Q:  do I need to flatten the top of the LED?
The early bird may get the worm, but the second mouse gets the cheese in the trap.
I prefer green or red diffused.
Don't flatten the top.
Josh
DutchMF
Red diffused worked like a dream on my build, but I haven't tried anything else, so it might get even better..
Paul
The circuit is remarkably un-picky about the LED (and somewhat about the LDR as well). Just about any LED will do the trick, but you may notice some will produce a more pronounced difference when the Depth is maxed out.
angrykoko
