Collosalus issue
Started by Axe_34, December 08, 2012, 12:49:20 AM
Axe_34
Hi all. Well the streak of trouble-free builds -- including a Dirtbag -- has ended.  ;D
Hooked the Collosalus up to my 9v test rig and I get no guitar signal. I can hear the effect working -- you can hear the flange swooshing and the controls effect the swoosh as they should. The problem is, there's no guitar signal being processed. I checked the usual suspects but didn't see any traces. Component values are good as are the electrolytic orientations.
I am getting some strange voltages on a few chips.
IC1 -- spot on
IC2
1- 7.20
2 - 7.2
3 - 7.18
4 - 0
5 - 0 (!)
6 - 13.71
7 - 15.71
8 - 14.38
IC3 -- spot on
IC4
1 - 4.02
2 - 4.02
3 - 3.98
4 - 0
5 - 7.2
6 - 7.26
7 - 7.26
8 - 14.4
IC5 - spot on
IC6 - spot on EXCEPT pin 5 is showing 7.18 instead of 0
IC7
1 - 1.74
2 - 4.25
3 - 0
4 - 8 mv
5 -  213 mv
6 - 2.5
7 - 1.43
8 - 9.09
IC8
1 - 15.87
2 - 0
3 - 14.46
IC9
1 - 14.46
2 - 7.16
3 - 7.91
4 - 1.37
5 - 0
6 - 7.19
7 - 7.81
8 - 7.81
I sure hope it's not IC9. I dropped $10.95 on that SOB.  >:(
I'm going to spend the rest of the evening audio probing. Wheeeeeeeeeee! What fun.  ::)
Any suggestions are greatly appreciated.
Them's some fancy capacitor solderin'. (Sodder-ing, if I was to extend the bad American accent :) )
Capacitors react differently to resistors when they're in series/parallel, is your maths right on those?
Axe_34
 ;D Frankencaps.  ;D
Just remeasured everything. Caps are fine but I found R26, R27, R41 and R47 are all off way more than 5%. Markings are correct but the values are out of whack. I'll replace those and see where it gets me.
Be aware that sometimes resistors measure funny in a circuit. Just because they measure wrong in the circuit doesn't mean they are wrong. They interact with other components.
Axe_34
Quote from: jkokura on December 08, 2012, 01:25:50 AM
Thanks.
Turns out it wasn't the resistors. Problem remains. On to the audio probe!
Axe_34
Well, I'm not getting signal on most of the circuit. I have it on the input and first resistor, but nothing after that. Think I'll take another run at this in the morning.  :-\
I have good news and bad news. Good news is that my 117 build works. Bad news is that I finally gave up on trouble shooting and ordered another board. Lazy, I know, but I finally threw in the towel. Your's looks very clean and I think I snuffed mine by lifting traces while trouble shooting. Hang in there, it's worth it.
Axe_34
Anyone know if the 3007 is prone to failure (like PT2399s)? Also, is there anyway to check the chip out of the circuit?
Quote from: Axe_34 on December 08, 2012, 02:25:47 AM
Based on that info, you need to start by verifying you can get signal into and then out of IC1B - if you can't get signal there, then the chips don't even matter yet.
Since IC1 voltages are good, there must be a reason that you get no signal after R1, and I'd start looking for that.
Jacib
Axe_34
Update: I worked my way through the circuit using the schematic and the only places where I'm getting a guitar signal are:
C6, R13 and VERY faintly on Pin 1 of IC1
Axe_34
Quote from: alanp on December 08, 2012, 01:10:02 AM
Culprit found! Replaced the frankencaps with single caps (as close as I could get to the stock values) and we have flange! And chorus! And a vibey thing too. This thing's a very versatile beast.
Thanks for the suggestion alanp!
