Egodriver Clipping modes
Started by teknoman2, November 01, 2012, 08:48:13 PM
teknoman2
I finally finished my egodriver and I believe its ok.
My voltages are 8.50v on pin8, 0v on pin4, 4.30v on pins 1, 2, 5, 6, 7 and between 4.15v on pin3.
I measure my dc and it is 9v.
If my dc input is 9v I believe I should have 4.5v, not 4.30v is there something wrong?
Also what is the best led for clipping?
I use red water clear with MCD 8000-12000.
Should I increase led MCD ? Something like MCD 12000 to 20000?
oldhousescott
R12 drops a little of the supply voltage, so your measurements look fine. If you socket your LEDs, you can try different values/colors/styles to find what you like best.
teknoman2
Does anyone use BAT41 for clipping?
Also both leds should light or only one of them?
Mine when I use leds only one (D4) light, is that correct?
oldhousescott
I would expect both LEDs to light.
