Flatline 1590A (SMD content)
Started by Ettore_M, October 06, 2012, 07:20:10 PM
Ettore_M
Hi everyone!
That's my Flatine! (Not exactly mine, because it was built for a friend. ::) But the layout is mine!  ;))
I'm very proud of this build, as it was my first 1590A build! I had my little problems with fitting the PCB (you'll see it's cut in an odd shape), as I misdrilled the jacks, but it came out perfect!
The Flatline is a great compressor and my friend already used it successfully on rehearsals! So i'm pretty happy he liked it!
The finish was a pretty painful job, as I had to polish and clearcoat the box two times, and also the lettering was done by hand using my dremel's engraving tool! But in the end, I really like the result of a polished box and engraved letters and I'm going to use this finish again on next builds.
Here's the build photos (The day on them is wrong, as I forgot to set it right on the camera settings. They were shot yesterday 5/10/12...)! : https://www.dropbox.com/sh/n22c4cxrwgv689w/2BdnIo9zJd
Hope you like it! :)
Hector
P.S. If you want me to upload the layout, just tell me so!  ;)
- Culturejam
GrindCustoms
SMD on etched board, that's is really cool! 8)
Flatline is really a cool comp, among my favorite, got couple other one in the work at the moment, but they'll need to be really good to put this one off the board. :)
Rej
Ettore_M
Quote from: GrindCustoms on October 06, 2012, 07:25:25 PM
Rej
Thanks, Rej! :D
They are indeed cool!  ;D They are pretty easy when you get used to working with them, but the fact that it is an etched board makes it more difficult to solder them perfectly straight! However, it works good enough for me at this moment!
- Culturejam
Very cool build, Hector.  I always like seeing SMD builds.  I agree, they are a lot of fun.
Ettore_M
Quote from: pickdropper on October 06, 2012, 07:49:39 PM
Thanks, pickdropper! But I'm just a follower. You are a master of SMD!  ;) Seeing your SMD Sea urchin build
inspired me to get more involved with SMD! It was like professional (or better industrial!  ;D) pedal building!
So.. Thank you!  :)
Hector
- Culturejam
