Rangemaster switch
Started by teknoman2, September 09, 2012, 09:55:43 AM
teknoman2
If I dont use SPST switch but SPDT (On-On) switch will I face any problems?
Is there any difference?
Quote from: teknoman2 on September 09, 2012, 09:55:43 AM
Simply leave the extra lug unconnected. SPST has two lugs -- no option for a second "on." SPDT has three lugs -- one common and two options.
The Bloody Omen
Hay, I saw that on his picture of the rangemaster that there was no SPST switch, unless it was wired to the top of the enclosure. And would it be reconmended to do a monitenary switch instead?
Thanks a lot,
5047N
The switch on MB's Rangemaster pedal is a tone switch, not a detune or similar, meaning a momentary wouldn't make much sense. It's optional, as well, which means that you don't HAVE to put it in. But being able to kick it down an octave from a treble to a midrange-treble boost if you want is fun.
The Bloody Omen
Ohh that helps a lot thank you alan, I will try to keep you posted with the final product yo and thank you.
From,
5047N
