Newbie parts question Part 1 - Fatpants
Started by Jazzman, November 14, 2010, 11:49:50 AM
Jazzman
Hi guys (and gals?), I've just ordered 4 pcbs... Fatpants, Cupcake, Glitterrattii, and Quasar. I've had experience building and modding Epiphone Valve Junior amps and other paint-by-numbers effects pedals, so my soldering is getting better all the time (still a long way to go though). I'm confident I'll be able to handle these builds (with a little help from you guys), but I'm having a little difficulty getting a parts list together. I'd prefer to order everything from Smallbear but it seems, they may be missing a few items... In the case of the Fatpants build, it's the IC and Electrolytic caps rated for 25v and over... Anyway, here's the shopping cart I've come up with, just wondering if I could get some of you more experienced builders to check it fr me (and other newbies searching this forum):
0911H   Metal Film 43K To 220K Individual
(100K)   $0.20    R1
0911J   Metal Film 240K To 2.2 Meg Individual
(1 Meg)   $0.20     R2
0911C   Metal Film 120 Ohms To 1K Individual
(470 Ohms)   $0.20     R3
(47K)   $0.20    R4
0911E   Metal Film 1.1K To 6.2K Individual
(4.7K)   $0.20    R5
(5.1K)   $0.20    R6
1155   Capacitor, Topmay TCM07 5mm Box, .001 mf to .1 mf.
(.1 mf.)   $0.25    C4
(.022 mf.)   $0.25    C2, C3
1301   Capacitor Silver Mica 500V 180 pf. - 430 pf.
(220 pf.)   $0.75    C1
1404   Capacitor, Electrolytic, Radial 16 V 1 mf. - 100 mf.
(47 mf.)   $0.20    C5
(10 mf.)   $0.20    C6, C7
2202   Diode 1N4001    $0.15    D1, D2, D3
2111   Transistor FET J201 Fairchild    $0.40    Q1
1015   Trimpot, Cermet
(50K)   $0.85    T1
1005A   Alpha Single-Gang 16mm, Solder Terms, Linear & Audio Taper
(100K Linear)   $1.25    Vol
(10K Linear)   $1.25    Fat
0301D   Box - Taiwanese 'BB' Size Yellow Powder Coat
('BB' Yellow)   $9.95
2302   LED T-1 3/4 5mm Water-clear High-brightness
(Violet)   $0.50
0600   Jack, 1/4 in. Mono Switchcraft #11
(#11)   $1.85
0602   Jack, 1/4 in. Stereo Switchcraft #12B
(#12B)   $1.89
0200   Switch - Taiwan Blue 3PDT
(Blue 3PDT)   $9.00
0611D   Jack, DC Power, 2.1 mm Plastic, Round, External Nut
(2.1 mm Plastic Round External Nut)   $1.25
0508N   Wire, #24 Solid Tinned Copper, Sampler    $3.95
0615   Bezel, LED 5mm, Chrome
(Chrome)   $0.70
0619   9-Volt Battery Snap
(Std Vinyl Snap)   $0.35
0816   Pointer Knob w/ Index, Black, White & Cream    $0.80
I assume that the Silver Mica cap would be an acceptable alternative for the ceramic disc type? Anyway, I hope I'm close with this list... Now I just need to find the electro caps rated for over 25v (I've included the 16v caps listed on Smallbear - but I wont purchase untill I get confirmation from you guys), and where to find the TC1044 IC.... Hmmm, hope this helps others in the same confused state as me! ha ha Thanks so much in advance guys... Soon I'll make purchase lists for the other effects too. Cheers!
Looks good. C7 is the only one where 25v matters. That said, it's possible that a 16v will work, but you do run the risk of failure. Shoot, I can send you one if you have trouble getting them (although Radio Shack or Frys usually has some good caps).
The 220pF is for high frequency filtering at the FX input. There isn't much benefit to using silver mica over ceramic. Actually, even 100pF there would be fine.
You can use the MAX1044 Steve has at SB. It's functionally equivalent, though a little more expensive.
Haberdasher
When using a super bright led, I have learned I prefer to jack the 4.7k resistor (r5) up to about 10k or it's way too bright for me.  Some people like it bright though, but I thought I'd mention it.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
CK1
Quote from: Haberdasher on November 14, 2010, 04:23:23 PM
Preferences appreciated!
Seconded. 10k metal film is my preference too.
Jazzman
Thanks guys, at least I know I'm on the right track now. Cheers!  ;D
Jazzman
#6
BTW, is the 1590B enclosure what Smallbear lists as the BB size? What size do you guys normally use???
I'm not sure, but I think you can get both the BB and the B from Smallbear. I prefer the 125B for single size pedals, the BB is good for larger single pedals or even dual function pedals sometimes.
