Ego Driver Optional Clip
Started by Comfort Player, August 26, 2012, 07:14:47 AM
Comfort Player
If I want to use default clipper in the ego driver so I just jumper holes 1 and 2 on the clip switch and omit the D4 and D5 LEDs ?
Silence..... I Keeeeeel youuuuuu....
You want to jumper pads 2 and 3 which are the middle and right ones on the PCB.
Comfort Player
Thanks for the info Brian.  I saw in the build docs that the led cipping was optional but was unsure on which switch position went where
