Afterlife IC orientation question (noob)
Started by fish22, August 03, 2012, 09:41:12 PM
fish22
So I'm just getting into this so please excuse what might be a noob question.
Is IC installed correctly here, or should it turned the other way?
Because this one doesn't have the little notch on the end I'm unsure of which direction is correct.
Hi, my name is Wyatt.
irmcdermott
You have it backwards. That little circle is pin 1 (the square pad)
fish22
murdog47
They are super sensitive to heat and static electricity also.  I would recommend a grounding strap from Radio Shack and use sockets instead of soldering the chip directly to the board.  I think it is probably near impossible not to fry the chip desoldering one.
