PCB WIRING
Started by mixermantim, May 28, 2012, 04:46:32 AM
mixermantim
I am about to start wiring my pcb slambox.  I am very new to making pedals.  How can you tell what side to wire the pot, 9 v power supply so on.  I am not really sure what side all of these wires attach to.
Thanks..
TC
mgwhit
bakelo
The standard wiring diagram will save you a to of headaches. Also coming from someone who just finished their first build, I would seriously consider using electrical tape on the pots and the back on the pcb. My first build had issues when I boxed it because of the pots making contact with the pcb. Good to ask to many questions I think.
Louis
slimtriggers
I highly recommend these boards to simplify the wiring:
http://1776effects.com/store/
Wiring the 3PDT correctly is probably the most confusing part of the build to a beginner.  Those boards make it almost a no-brainer 8)
