Boost and Ts808 suggestions
Started by night-B, June 03, 2012, 06:56:48 AM
night-B
Hi guys!
I'd like to put together a Ts808 and a boost in one enclosure.
Do you have any suggestions on boosts that work great with this circuit?
I have a slambox, a thunderpuss, and a fatpants board ready to go in that... Or maybe a baby boobtube?
Thanks.
Julien
DutchMF
I have a Thunderpuss that I use in front of a GreenBean, sounds quite good. You could wire them up with a 3PDT switch so the boost could be before or after the TS808 to increase flexability.
Paul
mjcyates
For me I would put a Fatpants after the TS808.
oldhousescott
I worked on a friend's Cheeseblocks sCream Cheese pedal. That's just an ITS8 with switchable LPB1s on both the input and output. Sounded decent and the boost really drove the screamer portion into a thick, saturated OD.
marmaliser
Two ts808 's would be my choice with boost one just being level max and gain min
night-B
So much options to explore... Think I'll test it before boxing to decide which one sounds best. Paul, how do you wire the switch to select the boost before/after the OD? Maybe a 4Pdt for the in/out of the effects?  ???
Is there a reason you couldn't build the enclosure to potentially try out multiple boost types to see what you like for yourself? Rather than limit yourself, I like having enclosures around I can switch circuits in and out of so I can try them live, and with a band, or in multiple rooms or with different equipment. Very handy.
Perhaps before you commit to one, try out several.
DutchMF
Quote from: night-B on June 03, 2012, 07:16:57 PM
You can do it with a regular 3PDT toggle switch, I have a pic of it somewhere, I'll try to dig it up.
Paul
DutchMF
Couldn't find the pic I mentioned, so threw together a new one. PLEASE DOUBLE CHECK BEFORE USING THIS!!!! This switches the order of to FX (or loops of FX). You could also use it to switch a fuzz/distortion before or after your wah, which is why started messing with this in the first place.
Paul
Haberdasher
#9
post deleted to avoid confusion
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
atreidesheir
night-B
