Jameco Pot grab bag?
Started by 9Lives, April 04, 2012, 02:21:27 AM
9Lives
I'm looking for a somewhat bulk order of pots just to have something to put in these builds. Maybe temp maybe not. I've managed to build a stock of all other parts except pots. I just can't seem to get a good enough stock on all values. I saw this grab bag for like 30$ but it's 1/5W - 3/4 watt linear, single and multi turn pots. It's like 300 pcs. Seems like a good idea just to have values for experimenting with until orders come in for the alphas. Question is can I use these different W pots? What is a multi turn? ( turns more than one turn?)  I'm assuming the normal pots we use are 1/4w? Thanks
You'll probably end up with a bunch of useless crap (huge pots or shafts that don't fit any of the standard knobs, etc). But for $30, it's not a huge gamble.
The "standard" pots we normally use in effects are 200mw (1/5-watt).
Multi-turn means that instead of having the resistance sweep range spread over one turn of the wiper, it's spread out over multiple turns. 10-turn is common. Multi-turn trimmers are great for dialing in the bias on BBDs by ear.
9Lives
ya I just ended up using tayda and order a sht load of everything. Most were like 50cent a pop.
