Let's say you've got a pile of Ge diodes ...
Started by midwayfair, March 15, 2012, 03:14:35 PM
and you DON'T want to use them in a drive/distortion pedal.
What's a ("good" or "bad") use for 'em? Any experience using them as substitutes in circuits where they don't necessarily belong?
(These are the generic Ge diodes from Small Bear.)
add4
build a dozen of pigrtonics philosopher's tone germanium edition about 7 ge diodes in one of them if i remember correctly.
Those diodes are used for the dirt section... so that won't help.
Unfortunately, about the only major use of Ge Diodes in guitar pedals is in clipping from what I've seen. That's not to say they can't be used elsewhere, just that its about the only use I've seen.
slimtriggers
Good use: You could give them away to guys who do want to build dirt pedals.
Bad use: You could make jewelry out of them.
*or you could build a Green Ringer ;)
pietro_moog
awesome, i gotta have the capacitor collier for my girlfriend  !!!!
(that's a joke)
Actually, my wife suggested making jewelry with the extra capacitors I got (I ordered a couple bags of 200 instead of individuals ... oops).
The Green Ringer is a pretty reasonable usage. I might try that.
a buffer, I think there is a schematic on amz effects
Several Compressors... The Hollis Flatline, Orange Squeezer.
Charge pumps, they have a low fV so you'll loose less voltage.
Several Octave Effects use them... Zvex Octane (can't remember what this one's based on) The Lowrider Pearl OC-7.
Anywhere you need a low voltage drop... any clipping stage you want to have sharp cut off voltage with soft/assymetrical clipping.
Dunno if you classify the Z.Vex Machine as a standard dirt pedal seeing as it creates crossover distortion? That uses some.
Quote from: Scruffie on March 18, 2012, 08:07:48 PM
Good idea. I was going to suggest power supply protection for the same reason.
djaaz
Well, here's a good use: Build some of these!
http://www.madbeanpedals.com/projects/Afterlife/Afterlife.pdf
I was planning on building one or two of them to begin with. This is great. :D
