Loophole leds
Started by Hangingmonkey, May 30, 2012, 11:12:52 AM
Hangingmonkey
Hi everyone in beanland. Ive just finished a loophole and it works fine. I notice that when i hit record, both the red and green leds come on and when play just the green. On the pdf it shows on the diagram that the red is for record and green for play.
How did it work out for everyone else?
Also, on a completely unrelated side note, in the context of an octaver pedal, what does tracking mean?
jtn191
iirc, the pdf says something about the green led being more of an "engaged" status and that it's normal
DutchMF
Tracking means how well an octaver can detect which note you play and generate the correct octave. Most of 'em 'track' better if you play higher up the neck, and almost all freak out if you play chords (except maybe the root-fifth powerchord).
Paul
