Wolfshirt Capacitor Question
Started by pryde, February 12, 2012, 12:00:23 AM
pryde
So I apparently ordered a 630v 47n cap on accident for C11 in my wolfshirt build. Obviously wy to big to fit so...
I found a .047mf ceramic (or mylar labelled 473M on it) cap in my bin. Is this ok or should I get a better poly-film cap at my local RS or order one?
Thanks for the advice
if it was me i'd use what I've got in hand, unless my life depended on it  ;)
Josh
djaaz
pryde
Cool. I will use what I got then.
So changing the value of C11 will give the pedal more mids? I have a .022mf on hand as well. Should I put it in instead of the .047 if looking for more mids?
Thanks for the help!
djaaz
Actually, i modded the FTM clone i built to a ultimate octave and played with different values there. I ended with a 15nf. You could socket this and then try whatever value you want depending on what you're searchin: fuzz or octave. I don't care that much for the FTM fuzz.
If you just want to close the box and forget about it, 22nf should be just fine.
