Plating etched PCBs
Started by pickdropper, January 22, 2012, 10:12:33 PM
Do you folks tin plate your etched PCBs or do you just leave them as bare copper?
I tried tinning an etched board with solder paste and a small solder reflow oven.  It didn't work very well.  :-)  It was a total mess.  I don't think I am going to bother doing that on any board that isn't solder masked.  A proper stencil helps a lot as well.
I tinned another board by hand.  That worked, but tool a lot of time and a bit of solder braid.
I ordered some liquid tin from mouser and will give that a go.  I hear it is nasty stuff, but we'll see.
So what does everybody here do?
Btw, let me put in a note on the quality of Haberdasher's etched PCBs.  I beat the living hell out of that first board and it is still usable (and finally reasonably cleaned up).  His boards are really well made.
Quote from: madbean on January 22, 2012, 10:28:26 PM
Liquid Tin FTW.
Good.  I am looking for an easier solution.
After you plate a bunch of boards, do you have to dispose of it, or can you put it back in the container and use it again?
Ettore_M
If I understood what you are talking about, you want a way to cover your etched pcbs not to get oxidized. If this is the thing you want, check out the Pictures thread at DIYSB for Guero builds and azrael's questions!  ;D (http://www.diystompboxes.com/smfforum/index.php?topic=36392.18380) Guero, uses a very interesting way, a transluscent spray paint!  ;)
Hope it helps!!
- Culturejam
