without opening up a GE-7 how to know if it's moddable
Started by jessenator, April 18, 2023, 06:45:53 PM
jessenator
Google is being dumb so I'll ask here—however, so am I sometimes, so hopefully it's not a question with an obvious answer:
Without opening up the pedal and seeing either a thru hole or smd populated PCB, how does one know if a GE-7 can be worked on? I know serial numbers can be looked at to see a date, so that may be one sure fire way, but if the SN is gone?
I should say, I'm not getting one for the sole purpose of modding it, but if I can find one, it's a nice to have avenue.
Thanks
"All you need is fuzz"   ~not Lennon
jessenator
#1
Well that's what it takes… i have to ask a dumb question and then the answer shows up not long after
I asked a better question "what year did ge-7s go SM"D, and it appears 2020 is when that happened
Post 2020 and Made in Malaysia? Apparently…
