Possible to socket an FV-1 chip?
Started by Aentons, June 18, 2020, 08:21:57 PM
Aentons
Has anyone come up with a way to socket an FV-1 on to a board that has SMD pads like the Headtrip?
The only socket type thing I see for SOIC chips are those expensive giant testers like from adafruit. nope.
https://www.adafruit.com/product/1281
However, I do see some SOJ sockets, but, those require the bent under type pins. Anybody tried something like this?
https://www.ebay.com/p/16012048571
You can see it a little better in this 40-pin version
benny_profane
Are gull wing sockets a thing? That's where I'd start, but I'm really not sure.
Aentons
#2
Quote from: benny_profane on June 18, 2020, 08:30:20 PM
They are, but I dont think the SOIC type pins will fit the holes like DIP pins. Also, maybe I missed it but Im not sure they make those in the 1.27mm pitch for SOIC
https://www.mill-max.com/products/new/smt-gull-wing-dip-sockets
Aentons
#3
Can the FV-1 pins be bent? Will they fit in a header like this, or are they too short?
1.27mm Right-angle Female header
Pitch: 1.27mm (.050″) inch pitch
The only thing I can think of is solving it or a daughter board and using headers on that. I think pedal pcb used to sell something like this for an fv1
https://www.mouser.com/ProductDetail/Aries-Electronics/LCQT-SSOP20?qs=%252Bfs1VP4DyWl739KC0%252BqLAA%3D%3D&gclid=EAIaIQobChMIo-Gu86qM6gIVEvDACh0TYw_EEAQYBiABEgJm7_D_BwE
I missed something.  Why do we need a socket again?
Aentons
Quote from: EBK on June 18, 2020, 09:50:36 PM
Because the fv1 is $18+ and money does not grow on trees  ;D
Aentons
#7
Quote from: Matmosphere on June 18, 2020, 09:46:55 PM
Those are thru hole DIP adapters which are much bigger. Most of the fv1 projects like the MB Headtrip and PedalPCB Arachnid are setup for smd pads on the board so it wouldn't really work with those
