Buff enclosure clear coat?
Started by Beedoola, May 05, 2020, 09:14:02 PM
Beedoola
I'm WAY too lazy but my stuff doesn't look as cool as others...
Usually requires a good length of time, days, for the finish to set up before you dare buff.
Willybomb
I used to cut back with some 1800/2000 grit wet/dry sandpaper, and then use a polishing compound.
But then I got lazy.  Three coats of Upol or Spraymax 1k gloss clear and I'm done.
Aleph Null
I'll sometimes use a polishing compound (like a light car polish) if the clear coat came out a little rough. I don't do any sanding; I've found it's too easy to burn through the clear coat and mess up the decal or paint.
