DoomButter new version question. (moved from Extra Projects forum)
Started by Guybrush, November 18, 2011, 11:29:07 AM
Guybrush
I recently ordered the newer version of the DoomButter from Haberdasher (great guy by the way!) which can be found on the FSB forum
http://freestompboxes.org/viewtopic.php?f=7&t=4000&start=120  (the PDF is about 3/4 down the page)
I'm just putting together a parts order list for this and a few other things and I'm a bit stuck with the SPST switch needed for the fuzz lift mod.  Should it be On-On or On-Off?
Thanks.
Either. An On-On SPST switch can be wired as both On-On or On-Off. An On-Off switch cannot be wired as On-On.
