guitar input -> USB-C recommendations
Started by mjg, October 23, 2018, 09:32:46 PM
My 6 year old laptop has started to have issues, so I'm going to replace it. :(
The old laptop had an audio line-in socket.  Worked great for occasional recording of the guitar.
New laptops all seem to be USB-C.  It's the way of the future apparently.
I'm looking for recommendations for a USB-C to line-in or guitar in converter thing.  Doesn't have to be super high professional quality.  Something that works with Garage Band on the Mac if possible (but I imagine pretty much anything that presents an audio source via USB will work?)
Oh, and I'll probably get some USB-C to USB 3 connectors anyway,  so recommendations for any sort of USB guitar input appreciated.  Doesn't have to be USB-C specifically I guess.
Isn't USB-C the same as thunderbolt port? There are several devices that I think might work. Check all the specs on the Presonus/M-Audio/whoeverelsemakesthemthesedays interfaces.
I like Presonus gear, but that's because it meets my needs in my price range.
sjaustin
My laptop is all USB-C. I use a Focusrite Scarlett 2i2 with a standard USB cable and an adapter. Works great.
Aentons
#4
Quote from: mjg on October 23, 2018, 09:37:02 PM
USB-C is a physical connection type
USB 3.0, 3.1, 3.2 are transfer rate standards
Most anyrhing with a USB-C port is generally USB 3.x capable. But it is possible to connect a USB 2 device such as an audio interface to a USB-C port
Quote from: jkokura on October 23, 2018, 10:14:58 PM
USB-C and Thunderbolt 3 cables are cross compatible, but the USB 3 and Thunderbolt standards are different and not compatible. You may have some devices that seemingly work with both if that device has core driver compatibility.
...Just a word of caution when selecting an interface.
BTW, I use a Roland DUO-CAPTURE EX USB Interface since it works with my old iPad and my PC
Cool, thanks, I'll check out those suggestions.
Thanks for the clarification too. Where I said USB 3 I should have said USB-A. The form factor, not the protocol.
It's 'awesome' how thunderbolt 2 had the same form factor as mini display port,  but wasn't necessarily the same... And now thunderbolt 3 does the same trick with USB-C.  I think the MacBook is USB-C only, the MacBook Pro is thunderbolt 3 + USB-C.  Confused yet?
