CHASM wiring - permanently on?
Started by Philthy, June 16, 2017, 03:54:46 AM
Philthy
Guys,
Posted this over at DIYSB with no luck...
I want to wire the CHASM permantely on in a multi-build.
Loooking at the schemo: http://deadastronaut.wix.com/index#!__build-your-own-pedal
I think I need to do this:
fs1 to 9v; and
fs2 to ground
Sanity check please.
diablochris6
You are correct. You could also save some parts and jump the drain and source pins of the wet signal and leave out the JFET switching on the bypass if the effect will always be on.
Philthy
