Total Recall powered by Pedal Power 2 Plus?
Started by spacekid71, February 10, 2017, 01:41:49 AM
spacekid71
Hi everyone,
I am considering a Total Recall build and I was wondering if my Pedal Power 2 Plus would power it. Below the description from Voodoo Labs for the Pedal Power 2 Plus.
Thanks,
Mart
Pedal Power® 2 Plus Features
18V/24V – Using Custom Cables
All of the outputs on the Pedal Power 2 Plus (and the original Pedal Power) are completely isolated allowing you to create different voltages. You can run effects like the current MXR Flanger by combining two 9V outputs to create a single 18V supply. By switching two outputs into 12V ACA mode, you can join them together to create a 24V output for powering numerous Electro-Harmonix stompboxes including the Deluxe Memory Man.
chordball
Definitely. It even mentions it specifically  ;)
