Naughty Fish On/On/On switch
Started by zombie_rock123, January 29, 2017, 09:59:02 PM
zombie_rock123
Just wondering if anyone has any sources for the switch in the UK?
The one from smallbear mentioned in the build doc has specific poles linked for the positions - http://smallbear-electronics.mybigcommerce.com/dpdt-on-on-on-pc-mount/
And this one doesn't seem to match:
https://www.bitsbox.co.uk/index.php?main_page=product_info&cPath=116_127&products_id=881&zenid=00ppm9ks2fs4thi6diuen3k807
bluescage
It doesn't seem to match, but that depends on how you define the contacts. But it's the same switch. The only thing different when I look at the picture is that the one from bitsbox is not a pc-mount one, but if you are not mounting it on a pcb that is of course no problem.
zombie_rock123
Unfortunately I'll be PCB mounting and the middle position seems to connect different poles ??? Smallbear order here I come!
bluescage
If you need the pcb-mount then you have to order that one. The connection of the poles however is the same only Smallbear and Bitbox have different numbering
1     4                                   1     6
2     5  (that's Smalbear's)      2     5  (that's Bitbox's)
3     6                                   3      4
zombie_rock123
Thank you so much, I was worried I'd sound stupid posting this question but it saved me money so what the hell ;D
bluescage
I've always been told that there are no stupid questions! :)
