univibe chorus setting
Started by shawnee, October 04, 2016, 02:20:19 PM
shawnee
Hello guys, I had a question about the chorus mode on the uni-vibe pedal (I guess that would be the Harbinger One around here). My son gave me an Earthquaker The Depths vibe pedal and it's fantastic. The problem is that there is no chorus setting and I probably won't use it without that feature. I looked at the Harbinger schematic and am trying to figure out what the difference is between the chorus and vibrato setting. Can anyone give me a rundown?
drolo
Usually in the univibe, what is called "chorus" is when the dry and wet signal are mixed together. The vibrato setting is the wet signal only.
I don't know what is under the hood in the depths but I would assume it is already wired with wet and dry mixed together.
shawnee
OK that makes a lot of sense. Thank you for the info drool.
