First Madbean build
Started by jonnygreentrees, September 26, 2016, 12:43:49 PM
jonnygreentrees
Bangarang's Mutron Phasor II clone.
I've built quite a few kits before but this is my first build (forgetting about my failed Clarinot) on single sided copper etch and my first build where I drilled my own enclosure.
Pretty pleased with how it's turned out
Wow! That is a killer decal. Post a gut shot too.
jonnygreentrees
Cheers!
Guts are a bit of a mess, most of the offboard wiring could be a lot shorter but I just wanted to get it boxed up
Looks Awesome!!! Great job, looking forward to seeing more of your builds.
mrclean77
Nice work! I dig the graphic and the inside doesn't look as bad as you describe.
We're such an odd lot (builders) when it comes to insisting on gut shots. I mean, I get the curiosity (I certainly am nosy enough to want a peek inside), but with very few exceptions do I see guts that don't fall in the category of "seen better/seen worse". It is neat to see what is going on in there and how different folks approach similar projects.
Looks great! I agree, don't worry about those guts too much. I had a bit of trouble getting the wiring on my Nutron that clean either, mainly due to the pot wiring.
jonnygreentrees
A bit of slack is handy too if you need to do any troubleshooting!  8)
Quote from: mrclean77 on September 26, 2016, 02:07:15 PM
Agree, and well said. Great build.
I love that artwork!
Also, high five for using the black laminate clad. I love that stuff. Look forward to seeing more from ya.
Looks super! I should really box mine up...such a nice sounding phaser.
darrenw6000
jonnygreentrees
Quote from: madbean on September 26, 2016, 11:43:43 PM
Thanks!
It sounded great but really subtle. The build doc only specifies a 5mm yellow LED which is what I bought, but when I looked at the Tayda LED Bangarang had bought for his original project it is 2000-3000mcd whereas the one I bought from Bitsbox in the UK is only 36mcd. I have now removed my original LED and am awaiting a 2500mcd LED.
So word to the wise, use a 2000-3000mcd yellow diffused LED for the correct effect
