Is SMD lowering our standards?
Started by alparent, March 01, 2016, 12:43:55 PM
thesmokingman
it would destroy your soul to see some of my pedal and amp builds using one color of wire for everything, and that color isn't color coordinated to anything.
EBRAddict
I've started doing hybrid boards, no point in using a 5 cent film cap for a 100nF power filter when a 0.9 cent X7R MLCC will do just as well and take up less space. Transistors can be found for 1.3 cents each and resistors 0.5 cents. The boards are generally 2/3 to 1/2 the size if you use 0805 sized passives.
That's a good trick I got from Jurgen Haible, actually -- instead of 100n bypass caps everywhere, put them on the bottom as 0805's
