Another Broken Weener
Started by brucer, March 26, 2016, 02:41:09 AM
brucer
Hi All.
I've built up a Weener Wah II and it's DOA signal-wise.  I checked it with my testing rig before boxing and it was passing the test signal, so I thought all was well.  After boxing I'm getting test signal EVERYWHERE I touch the probe except at the output ... and there doesn't seem to be any wah effect added to the test signal.
So, for starters, a couple of questions:
- How far should I disassemble this beast in order to troubleshoot effectively?  Do I need to remove all the offboard wiring options?
- Is there a way to check the wah inductor once installed on the board to see if it's passing signal correctly (i.e. to check that I used the right holes for that inductor)?
Any advice or direction would be appreciated.
Thanks, Bruce.
Check your off board wiring and make sure nothing is grounding out.
