Doombutter question
Started by matmosphere, February 24, 2016, 07:04:37 PM
Built up my doombutter last night. Rocked it (out of the box), realized the volume was wired in reverse. I switched the wires, didn't rock it again, boxed it.. Fail
Had to leave it and take care of other things, but I remembered after I left about switching the wires. I checked over the off board stuff and it's all fine. Should I switch the volume wiring back? I guess I'm assuming the volume would just work I reverse if lugs 1 and 3 were switched. Am I incorrect on that? Maybe I just thought it was backwards.
Should work. Are you sure you don't have a bad solder joint on your volume pot after the switch? Or that your wiring is correct? Nothing grounding out against the enclosure? 9V wire soldered to the wrong lug on your DC jack? Lots of room for things to go wrong in boxing.
