Fender Tone Box suggestions please
Started by JoeDorcia, April 05, 2015, 01:45:47 PM
JoeDorcia
I'm planning a multi build that will give me some tone shaping ability, not so much interested in drive/gain, but to give some colour to my tone. The clean channel on the Laney IRT-Studio I play is a good base for effects but also fairly lifeless. My plan is a multi that switches between an ROG English Channel and some kind of fender tone. I was looking at the Lovepedal Les Luis clones, Wampler Tweed 57 and Black 65. The latter two look more gain based and emulate the cranked amps they reference. Any good ideas for me to consider would be greatly appreciated!
Making noise since 2001... If only I knew what I was doing
Instagram.com/Twitter - @JoeDorcia pictures and pretentious ramblings about my son, coffee, food, pedals and guitars...
playpunk
Flabulanche?
"my legend grows" - playpunk
micromegas
Black 65 sounds good. I've heard a lot of good things of the ROG Azabache too.
Software Developer @ bela.io
Black '65 is indeed excellent. Great clean sound and you always have the extra gain stage on a switch.
I run mine at 15volts and biased for that value. It's great.
JoeDorcia
Thanks for the suggestions, Black 65 looks like a winner. I like the idea of running it at a higher voltage, I'll whack a charge pump in and bias it as you say. Best get designing!
JoeDorcia
Quote from: jubal81 on April 05, 2015, 07:02:00 PM
just been reading more on Tagboards about biasing the FETs, when running at 15v do you get more headroom and, as I haven't done it before, what drain value would you be aiming for when running at 15v? Or is this still the 4.25-5v?
Quote from: JoeDorcia on April 05, 2015, 10:45:04 PM
The flabulanche is 2/3 of the output of the charge pump, I'd do that here also, then play around with it. I biased a prof tweed kind of high and it wasn't quite as distorted.
