Ninety Ninety (NomNom)
Started by mcallisterra, March 29, 2015, 11:23:57 PM
Jebus
Quote from: TreeSlayer on March 30, 2015, 09:20:44 PM
i just downloaded the PDF. it doesn't say how to make the reverse image. is that a function of the printer?
lt
You can do that with any image editing software. I don't know if even Microsoft Paint can nowadays do it. I use free software called Gimp.  :)
looks great dude, nice build :D
pryde
Quote from: Jebus on March 30, 2015, 09:36:43 PM
lt
I use Inkscape to create the image then there is a "horizontal flip" button in the toolbar. Whatever you use there should be something similar you can do to the image.
TreeSlayer
Quote from: pryde on March 30, 2015, 10:19:06 PM
lt
cool! i'll check in to it.
"At the line it's just you, me and the tree." the TreeSlayer
"You have the rest of your life to make excuses and be a fuckin' pussy. Today is your day OFF!"  Amiri King
TreeSlayer
Quote from: pryde on March 30, 2015, 03:56:39 PM
Here is a link if you want to check it out: Thanks
https://www.dropbox.com/s/bzpig6axmhhpltm/Enclosure%20Etching%20Tutorial%20JPGuitarworks%202013.pdf
lt
I assume that etching is only black and white? no color.
LT
mcallisterra
Nothing that you actually print will stay on the pedal. It is just acting as a mask to block the acid from certain areas. You could theoretically paint it however you liked afterwards by spraying a color over it then sanding it flat (leaving the color in the etched areas).
mcallisterra
