Pork Barrel v2
Started by LaceSensor, November 09, 2011, 02:01:03 PM
Hi,
Is it possible to do the blinking light LED trick from the PB v3 build doc on the v2 pedal?
thanks.
joe*211
Another question for the v2 board - is it possible to fix the depth as always full?
I spose I could always just wire a trimmer internally that might be an idea!
Yes you can totally do that. I suggest using a trimmer, as that will allow it to work correctly. Otherwise you could use a pair of resistors, one from pad 2 to 3 and one from 2 to 1.
