LG_SHO boooooster with optical bypass in 1590a
Started by rullywowr, January 28, 2015, 10:12:59 PM
rullywowr
Based off the Landgraff Clean Boost.  Really great circuit, I love how it adds a bit of fatness/warmth to the drive.  It's circuit is similar to a SHO.  If you want to build your own, I created a project "LG_SHO" and tutorial (complete with build doc and single sided etching artwork) here in this thread (if you haven't seen it already):
http://www.madbeanpedals.com/forum/index.php?topic=19463.0
Specs:
1590a powdercoated Gloss White (by me)
Detour Optical Bypass (for no-pop) switching
Low-Profile Alpha DPDT for smooth stomping
Flat-Top 3mm clear blue LED
BS170 FET (you can use 2n7000 as well)
Custom clear/green swirl knob by Sean at SRC Effects.  Sean makes awesome knobs.
http://srceffects.com/
Kobiconn low-profile 1/4" jacks.
PCB etched and "Liquid Tinned"
copachino
Its a new layout of thr detour?? The pones i bought have the c2 180 degrees so i can fit them on 1590a.. Also where do you buy those jacks???
Awesome looking build. I love that knob, I need to contact him and see if I can pick some up... He's been super busy it seems.
I also can't wait to gibe you Detour Optical Bypass a try since you hooked me up with one.
rullywowr
#4
Quote from: copachino on January 29, 2015, 12:20:38 AM
This is the latest and current version of the Detour (v1.3). I wanted to make it as small as possible while maintaining symmetry for LED mounting. I just nibbled the corners off with side cutters for this one. Send me a PM with your address Copachino and I'll be glad to send you some of this version  as a courtesy for free to replace your earlier ones.  ;)
EDIT:  The Kobiconn jacks were purchased a few months back as a group buy.  Mouser has them, however you have to order a minimum of 1000 it seems.
I do see you can get the jacks here
http://www.retroamplis.com/Open-Jack-Mono-special-size
Awesomeness in a tiny box! Dig that knob too and great all around finish!
chordball
You make it look so roomy in there! Excellent work man.
copachino
Quote from: selfdestroyer on January 29, 2015, 06:22:59 AM
ive found this on mouser, but they are switched, still im going to ask for 6 to see how big they are
http://www.mouser.hn/Search/ProductDetail.aspx?R=161-MJ160M-EXvirtualkey11180000virtualkey161-MJ160M-EX
Coda-effects
Really nice ! How did you powdercoat it so nicely ?
rullywowr
Thanks for the kind words everyone!
Quote from: Coda-effects on January 30, 2015, 08:33:53 AM
Thanks man.  Just like paint, its all about basic prep.  Pre bake the enclosures at 375 for 20 min (this gets any internal gasses out and stuff).  Then cool and wipe the enclosure with Acetone and a rag until no more black stuff comes off.  Attach electrode and hit it with glossy white powder evenly.  Bake in my beat toaster oven for 10 minutes until flow out occurs.  Check to see if you missed any spots (if so, take it out and hit it quickly again) and continue baking for a total of 20 min.
