ID this resistor for me please
Started by mcallisterra, December 11, 2014, 09:04:04 PM
mcallisterra
I usually check resistor values with this one site where you just punch in the colors and it tells you the value, because I'm not good at remembering all the codes. Anyway this one resistor isn't coming up with what I expected, so I think I got sent the wrong one. I was wondering if you guys could tell me what it is? Thanks!
If it is BROWN-BLACK-BLUE-GOLD it should be 10M 5% tolerance. (Not sure whether the first ring is brown or red. If it's red it should be 20M)
No guarantee though
Do you have a multimeter? this would give you a definitive answer for sure.
mcallisterra
I don't have a multimeter no. That's why I was asking on here.
The first ring is brown so yes it's 10M. Which is annoying as it's supposed to be 3.9M!
Thanks for the quick help though!
televisiondown
"Be more constructive with your feedback, please" ~Jemaine Clement
Bad to hear. that value is way of your ordered 3M9.
Fyi, 3M9 would be orange-white-green-gold
maybe someone here can send you some. Where are you from?
muddyfox
I don't even read codes anymore. DMM every single resistor I solder, keeps stupid 2AM mistakes to a minimum (at least the resistor based ones  ;D ).
mcallisterra
Darn. maybe someone more local can help out. it doesn't make sense to ship one resistor from Europe :P
I guess a resistance value that high is most likely for a pull down resistor, right? I think (let someone confirm this) that you could substitute it for a 2M or similar, if you have it...
mcallisterra
Quote from: m-Kresol on December 11, 2014, 09:45:50 PM
I haven't really built many pedals, so I don't have a backlog of parts. I just order what I need for each build. This is for a Nom Nom.
I have lots of 3.9M resistors - 1% metal film.  PM me your address and how many you need & I'll get some in the mail tomorrow.
mcallisterra
Quote from: bcalla on December 11, 2014, 09:58:20 PM
Awesome! Thanks so much!  :)
Quote from: mcallisterra on December 11, 2014, 09:24:21 PM
I strongly recommend you pick one up as soon as you can, if only for resistance and continuity checking.
mcallisterra
This post kind of made me realize that yea!
