Lovepedal OD11 and Paul C Timmy
Started by J. Ignacio, November 03, 2014, 08:15:50 PM
J. Ignacio
Hi guys, I'm looking on web a pcb to build Lovepedal OD11 and not appear. Searching I found that is very similar to Paul C Timmy overdrive, some value change, the big difference are extra diodes and dip switch on Timmy.
I found a pcb for timmy, so if I remove extra diodes, dip switch and change some value it work fine?
I tryied to make a pcb on eagle but i have lots of problems.
Image to compare
OD11
Paul C Timmy
J. Ignacio
Thanks brejna but this pdf have the boost part and i don' t want to.
