Slow Loris home made PCB
Started by willyboy, October 21, 2014, 02:25:31 AM
willyboy
This is my first build report on this forum!
Introducing my Slow Loris :
I redesigned the PCB myself with DipTrace with the components and potentiometers where i wanted them to be. Here's a pic to give you an idea what this looks like inside :
The schematics of the PCB is the same as the Slow Loris (except a slight modification on the DC filter). Like i said, i only redesigned the PCB my own way.
Being in an appartment, i can really krank up my amp to give it a real test, but from what i heard, the Si/LED switch as well as the CUT control really gives a lot of variations in the grain and the characteristics of the distortion.
I haven't failed, i've only found 10,000 ways that won't work
-Thomas Edison-
chuckbuick
Nice job! Very well done. I like your graphic a lot and you did a nice job on that board. Hope to see some more from you.
luks999
looks fantastic :) always wanted to try a rat :)
i see have to work more on the printings ;)
